how to smoke lights?
Old 05-07-2007, 12:00 AM
nine five cam's Avatar
Default how to smoke lights?
[align=center]i was wonder what the easiest way to smoke tail lights by myself.[/align]
Old 05-08-2007, 02:01 AM
Default RE: how to smoke lights?
so i have been doing some research, what do you think about VHT nightshades.
pros and cons of spray vs. vinal covers?
thatnks
Old 05-16-2007, 03:31 PM
mikeynavy1's Avatar
I'd like to learn about this too. I'm a little afraid of the spray.
Old 05-16-2007, 09:09 PM
akira751's Avatar
The spray scares me too.
[align=left] [/align]
Old 05-16-2007, 11:06 PM
rikk0's Avatar
I know there's a website that smokes tails and head lights. It's a 3 day turn around. You send them out Monday and get them back Thursday I belive. I would love to do it because it seems they do great work, but I can't do without my car for that long.
Old 05-21-2007, 08:48 AM
lavalleemike's Avatar
I once used a spray product on my tails and 350 dollars later i had new non smoked taillights.
Old 05-21-2007, 08:33 PM
j kellz's Avatar
i smoked mine with the spray and they came out awesome. ill take some pics in the am and post them up. ps. i had it on an 05 camry
Old 05-22-2007, 05:15 AM
Guess it depends on the product what did you use
Old 05-24-2007, 03:26 AM
boogz's Avatar
Im kind of skeptical on the spray. If you end up screwing up your lights because of the spray you might need to buy a new set of lights, which arent that cheap.
Old 06-11-2007, 01:31 AM
4ageBT's Avatar
ORIGINAL: nine five cam
open your headlights using hair dryer and screwdriver. heat up the corners where the sealant is placed then pull it gently.
after opening your headlights. cover the part that are not supposed to be colored. then use a high heat flat black paint to paint the part that you want to smoke. ley it dry
then use clear silicone sealant to re seal your headlights. just be sure that you put the silicone evenly to prevent leaks.
peppermintoj
11-16-2009 12:34 AM
BlackedoutCamry
08-13-2009 08:57 PM
jetfire
07-03-2009 02:34 AM
jthm
05-14-2007 12:46 PM
KillaCam05
03-29-2006 05:20 PM
Quick Reply: how to smoke lights?
