need help taking out brake light assembly..
hi guys need helphow to remove the brake light assembly on 2010 camry se v6 i want to put tint on my brake light but i cant get em off.. if somebody who can teach me or post a link that'll be great thanks..
Might ask at the Toyotanation website.
Typically the rear light assy has threaded studs that install through chassis holes and held on with nuts. Pull back the inner trunk liner or remove the lamp trunk liner access cover and look. There may also be a plastic clip molded to the assy that comes through the side of the chassis. You may see the clip extending through the chassis from inside the trunk. Once the nuts are off the assy may require gentle manipulation to remove it as the studs and clip can hold the assy snuggle in place. Don't force it. |
