rain in lights?
Old 06-10-2006, 09:53 PM
burger's Avatar
Default rain in lights?
What do you do if you get water in the clear corners or clear turn signals? help pleezzzzz
Old 06-12-2006, 11:38 AM
v6kamree's Avatar
Default RE: rain in lights?
pull them off and let them drain they should holes for drainin or just let it drain through the hole where the globe is normally, only way i kno
Old 06-13-2006, 03:04 PM
burger's Avatar
i tried that and now its all cloudy inside
Old 06-14-2006, 07:31 AM
v6kamree's Avatar
cloudy will more than likely mean there is still moisture inside have u tried using a heater under the lens so when it heats up it will escape through the whole since hot air rises, (without pullin them apart thats the last idea i kno of)
Old 03-14-2008, 10:05 AM
Camrymodder's Avatar
Remove your lens,(and the bulb of course) take a mix of 75% rubbing alchohol 25% water and puor just enough in to fill about a fourth of the lens. slosh it around, and pour it out. let the light sit overnight at an angle so that the lens is like it would be in the car to help but the alchohol should evaporate quickly and leave behind little or no water spots.
carid
08-10-2015 08:01 AM
Masterwood55
03-04-2014 08:39 AM
facebook
08-27-2010 04:26 AM
jetfire
07-03-2009 02:34 AM
scottroberts
10-25-2008 09:03 AM
Quick Reply: rain in lights?
