Removing Clear corner problem
I am in the process of replacing my stock front signal corner light, with clear corners.
however i am having trouble removing it. Does anyone know how to take it off, or know where i good get instructions for this? i appreciate it |
I don't familiar on removing lights but I think I read an article about this in ezine articles. its was very informative.
You just gotta pry it a bit off with a screwdriver forward toward the front of the car. Just slip it in between the corner lens and the car body and nudge it outward. You should hear a popping sound that will let you know if its off or not because its held in there with plastic clips which of course clip into each other. After that you will juss have to disconnect on wire and your good. Lemme know if you need more help.
~Vee |
Yep, IS300 lenses......no trouble to install......I wish we could find some clear lenses for the rear bumper reflector... Id wire it for lights....
