What part is this under air dam or is it air dam
2 Attachment(s)
Hi - new, this may be answered but could not find. Can some one tell me what this part is called. the part sticking down from under the air dam under the splash guards. held on by brackets near front of tire well. Mine only has the brackets with nothing in center. Car pictures shows part. Not sure where mine is, maybe wife ripped off over parking bumper. Thanks
Hopefully shows in pictures. |
You're talking about those two little plastic pieces in front of the tires?
Yes, but Looks like used to be a single part that went all the way across? Both of mine were loose and end looks broken.
Year of car and model such as hybrid or conventional?
Does the area of part sticking down belong to the wheel well inner fender splash shield or lower radiator splash shield? |
07 Camry LE.
Maybe it never went all the way across and just came loose at both sides but I think it used to? |
The car has a two piece (L/R) engine under cover.
Those pieces are separate and are like little ducts in front of the tires. When you remove the lower engine cover (both sides), you remove those first. I think they are there to direct air to the rotors for cooling.
