08 Camry LE Aftermarket Amp and LOC problem
Hello, I am new to this forum so thanks for all the help in advance =]
NOTE: I am pretty new at this audio stuff, i'm trying to save some money and learn at the same time. 1. My problem is that my amp keeps on turning off after about 10 minutes or so of driving. If I leave my car there with the audio on though, it can run for 1 hour +. The only way I can get my amp to turn back on after that is if I unplug my negative on my battery, then plug it back on. Then my amp will turn back on for about 10 minutes of driving....Then back off again. 2. Also my auto locks with my remote won't work if my amp is plugged in. I have no idea why that is. 3. There is also a feedback type of noise or humming coming from my speakers regardless if I have music on or not. This only is present when my amp is on. 4. Also, my car radio does not turn on or off by itself when my amp is on, I have to do this manually. There is also a THWUMP noise when I turn my car radio on. Is this normal? I also noticed that my amp is constantly on regardless if I have my keys in the ignition of not. Did i wire something wrong? I followed a wiring diagram, but since it's always on, does this mean I wired something wrong? I will provide some info on the equipment I am using. If you guys could help me out a bit, that would be awesome. Be easy please! I'm learning I recently installed: With Factory radio and 2 Line out converters LOC: PAC SOEM-T 2-Channel Premium Line-Out Converter with Remote Turn-On Trigger for the subwoofer PAC SOEM-4 4-Channel Premium Line-Out Converter with Remote Turn-On Trigger for the front door speakers Front Door Speakers: Polk Audio MM6501 Amp: CPT4-1400 1,400 Watt 4 Channel Amplifier Sub: JL Audio 12w3v5 |
What is the stock Toyota radio set up? A radio/amp combo unit or head unit and remote amp setup?
Where did you install the line-converters? When the amp turns off by itself does the Protection LED light up? Feel the amp case and determine if it is very hot after it turns off. Auto locks as in door locks? Did you ground the amp (using Ground connection on the amp) to the a good chassis ground point using a length of wire 3 feet or less? How is DC power routed to the amp. Directly from the battery or using 12V picked up from the cars wiring? If the amp is always on, you might experience a thump noise as the head unit is turned on. How did you connect the remote wire to the amp? From the line out converter? How did you connect the speakers to the amp? These speakers are 2 and 2.7 ohm impedance. You need to match as best as possible the speaker impedance to the amp output impedance setting capabilities. Obtain a volt meter. With ign off determine if there is 12V at the remote connection on the amp. What wiring diagrams did you use? |
I kept my factory head unit there and I just added LOCs and amp
I installed one LOC right behind my headunit and the other one in the trunk next to my amp. I checked the amp before and it doesn't seem to heat up after awhile. My locks work, but only if use my keys and manually unlock it via key hole. my remote controller unlock no longer works if my amp is turned on. I have the 4 gauge power wire coming from the positive terminal of my battery and routed back to the trunk on the drivers side. my rca's and blue remote wire are routed back on the passengers side. Yes whenever I turn on my radio, i hear the thwump sound. My blue remote wire is connected to the: 3.Grey (GR) Accessory power [switched on with the ignition switch] +12v and routed back to the amp. I connected speaker cable from my amp to the crossovers i have for the speakers. Then from there, i hooked up the tweeters and speakers to the crossovers which are located right about the driver and passenger foot area. In the cavity/free space with other wires. I just used the information below to wire from the factory wires to the LOC F6 Pins: 1.Light Green (LG) Front Right (FR) plus (+) speakers source 2.Pink (P) Front Left (FL) plus (+) speakers 3.Grey (GR) Accessory power [switched on with the ignition switch] +12v 4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory] 5.Light Blue (L) Front Right (FR) minus (-) speakers return 6.Violet (V) Front Left (FR) minus (-) speakers return 7.Brown (BR) Ground (GND) radio ground 8.Orange (O) Antenna Amplifier (ANT) power source 9. No Connection 10.Green (G) Night Lighting [+12 when the taillights are turned on] F7 Pins: 1.Red (R) Rear Right (RR) plus (+) speakers source 2.Black (B) Rear Left (RL) plus (+) speakers source 3.White (W) Rear Right (RR) minus (-) speakers return 4.No Connection 5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster. 6.Yellow (Y) Rear Left (RL) minus (-) speakers return F8 Pins: 1.No Connection 2.No Connection 3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.] 4.No Connection 5.No Connection 6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common] 7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-] 8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice) 9.No Connection 10.No Connection 11.No Connection 12.No Connection 13.No Connection 14.No Connection 15.Orange (O) Auxiliary Right Input (ARI) 16.Brown (BR ) Auxiliary Shield Ground (ASGN) 17.Red (R) Auxiliary Left Input (ALI) 18.No Connection 19.Green (G) Auxiliary Input [Sense](AUXI) 20.No Connection |
When the amp shut down occurs check the Protection light on the amp. If the amp goes into self protection it will shut down.
From the wiring info assume the audio system has the navigation feature plus a remote amp, yes? Take it you have the wiring diagram? Please review again the installation. Assuming the audio system is as described above: Did you add additional speakers or replace the factory speakers with your speakers? How did you handle the original Toyota amp? Was it fully disconnected? The new amp is in the trunk? The rear LOC was wired how. Taped off the original amp speaker output wires? Are there speakers still hooked up to the original amp speaker wires? How was the LOC behind the head unit hooked up? Where did you tap into the gray wire? Make sure the new amp is turning off with the ign key and if the old one is installed check this also. |
