2002 camry dash
I've been trying ALL DAY to get my factory cd player (jbl) out of my dash. I seem to be able to get everything off of the dash EXCEPT for the center where the cd player is located.
I just bought this car, and I have been driving a 88 landcruiser. I had an Amp and Sub in it, and I would like to put them in the Camry. I found the factory amp behind the glove box, and I'm not sure what to do with it either. Does anyone have ANY IDEA on how to do this? Or at least just how to get the dash off, that would help a ton cause I could figure most of it out from there... Thanks!!! |
RE: 2002 camry dash
ya dude. its ****ing tricky as ****. but there are four bolts i think on driver and passenger side of the car. and with the center, where the deck is. if you look down the center dash you will see either an ash tray, or a little storage box that slides out. pull that thing out, then put your hand in that hole and pull the whole center out. you have to jimmi it a little, but it should just come out nice. be carefull not to scratch your dash tho. there are little pockey metal shards around the edges. then you will have 4 or 6 bolts around your deck and AC controller. it should be a 10mm. if not, whatever. you will then need of course a ratchet with an extension. then pull the ****er out.
