Camry Forums - Toyota Camry Forum (https://www.camryforums.com/forum/)
-   Audio/Visual Electronics (https://www.camryforums.com/forum/audio-visual-electronics-11/)
-   -   2011 Camry le not JBL Radio Wiring (https://www.camryforums.com/forum/audio-visual-electronics-11/2011-camry-le-not-jbl-radio-wiring-40184/)
dmarr35 02-18-2012 05:11 PM
I need color code wiring for standard radio not JBL Thank YOU
toyomoho 02-19-2012 02:48 PM
Might be:
Gray = ACC
Blue/Yel = Power
Brown = Ground
Violet & Pink = Frt Door LH
Blue & Light Green = FD LR
Yel & Blk = Rear LH
White & Red = Rr RH
dmarr35 02-19-2012 03:39 PM
Thank You Joey P I have a RaadWire radio I am installing I figured it out except the ant on factory has 2 inputs and when I put the large one in I get poor reception I will have to contact RoadWire for ome help the stering wheel also does not work.
toyomoho 02-19-2012 11:37 PM
The large cable may be the antenna.
What color is the other antenna wire, orange? If so this is for a antenna amp.
dmarr35 02-20-2012 05:38 AM
It is blue smaller then black
toyomoho 02-20-2012 10:00 PM
Is the antenna built into the rear window, on top of the car, a mast antenna and if so automatic extend and retract?
dmarr35 02-21-2012 05:35 AM
Problem fixed power to ant was not hooked up I did not has a wiring diagram so I retraced the few wirers I did not use it says orange for ant but it was brown, Radio is great now Thank You.
mikejordan 02-23-2012 02:29 PM
while comparing black it is big and blue in color
igorep 01-25-2013 05:57 AM
what is the blue smaller then black wire with small brown wire connected to, the reason why I'm asking is because I installed aftermarket double din sys and it did not had any input for this cable and now I have some issues with the radio signal.
