!!SOS!! BROKEN STEREO?!?! HELP!
HELP A SISTA OUT!!!!!!!!
I recently obtained a 1992 Toyota Camry V6 LE. It's been under non-op for about 3 years. I purchased a new battery, new tires, new brakes, the works. After all the money spent, my stereo went out. The radio shows the station number when its on, the antenna goes up, I hear static but no music! I don't know if its a loose connection or I need a new stereo. What is a girl to do???
RE: !!SOS!! BROKEN STEREO?!?! HELP!
Well first check the back of the unit and see if there is in fact a loose connection. It should be a semi-thick black wire which runs from the antenna to the back of the unit. You never know, you might not need to spend any more money.
