How big is a 1999 Camry XLe v6 Trunk?
The reason I ask how big the trunk for my car is because I am trying to figure out if it is possible to fit a 5-8 cubic feet box into my trunk.
I am trying to figure out if it will be possible to build a sub woofer box that big into a camry because the specs recommends that size of a box for best performance. BTL18 DUAL 1 | DUAL 2 Fs: 32.6 Hz | 32.1 Hz Re: 0.7 Ohms/coil | 1.5 Ohms/coil Qms: 6.11 | 6.20 Qes: .28 | .26 Qts: .27 | .25 Mms: 298g | 307g Cms: 0.80mm/N | 0.80mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 164.2 l | 164.2 l Spl: 94.9dB 1W/1m | 95.1dB 1W/1m Bl: 17.5 N/A | 26.9 N/A Bl: 00.0 N/A | 00.0 N/A Xmax: 16mm * | 16mm * Rms: 2000W * | 2000W * Sealed box: N/A cuft | N/A cuft Ported box: 5-8cuft | 5-8cuft Sub OD: 18.500” | 18.500” Cut ID: 16.750” | 16.750” Mounting depth: 9.750” * | 9.750” * Displacement: 0.26cuft * | 0.26cuft * Product code: 00218 Price: $ 409.00 https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=1547844c631726e/shopdata/0010_BTL/product_overview.shopscript I've heard of people building a box a particular size but when it comes down to "Putting it into the trunk", they can't fit it. |
RE: How big is a 1999 Camry XLe v6 Trunk?
Holy crap dude, are you going to be going into SPL or SQ competitions. The sub is WAYYYYYYYY overkill. The ONLY time I've ever seen an 18" sub was at a SPL comp and the VAN was a rolling speaker box. If that's what you doing, that's your perogative, but if you're not, please rethink your decision. (i.e. one 12" sub)
I currently have two 12' subs in a 3 cubic feet ported box.
They're only getting around 600 Wrms total. In the near future, I plan on buying an "Fi BTL" sub, but the reason I'm thinking about going with the 18' because the price difference for the sizes aren't that big of a difference. It's $500 for the Fi BTL 18' sub "fully loaded" (aka extra features). And nope, this will be for daily use not for competitions =P |
