need 2009 Camry factory radio wiring diagram
Per title, I am in need of 2009 Camry OEM radio wiring diagram, any help would be much appreicated.:)
Hello, anyone??????:confused:
If its the same as the 08's
2008 TOYOTA CAMRY 4DR SEDAN WITH 2.4L ENGINE AND JBLŽ 8-SPEAKER AUDIO SYSTEM Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery BLUE & BLUE YELLOW (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS Power Antenna ORANGE (+) RADIO HARNESS Amp Turn On THE AMPLIFIER TURNS ON WITH THE ACCESSORY POWER IN THE VEHICLE LF Speaker (+) BLACK THESE WIRES PROVIDE THE AUDIO INPUT TO THE AMPLIFIER LF Speaker (-) WHITE RF Speaker (+) RED RF Speaker (-) GREEN Amp Location UNDER THE FRONT RIGHT SEAT Steering Cntrls YES Speed Cntrl YES Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery BLACK (+) IGNITION SWITCH HARNESS Ignition 1 YELLOW (+) IGNITION SWITCH HARNESS Starter 1 BLUE (+) IGNITION SWITCH HARNESS All Door Trigger BROWN (-) AT VEHICLE FUSEBOX Domelight Super BROWN (-) AT VEHICLE FUSEBOX LF Latch BLUE (-) AT BECU MODULE IN VEHICLE FUSEBOX RF Latch YELLOW (-) AT BECU MODULE IN VEHICLE FUSEBOX LR Latch LIGHT GREEN (-) AT VEHICLE FUSE BOX RR Latch GRAY (-) AT BECU MODULE IN VEHICLE FUSEBOX Trunk Trigger WHITE (-) AT BECU MODULE IN VEHICLE FUSEBOX Hood Trigger RED (-) AT VEHICLE HOOD PIN SWITCH Alarm Disarm BLUE (-) INGITION SWITCH HARNESS Parking Lights BLACK (-) AT BECU MODULE IN VEHICLE FUSEBOX Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo PINK (-) AT BECU MODULE IN VEHICLE FUSEBOX All Hazrd Lights WHITE (-) AT VEHICLE HAZARD SWITCH Wipers-Lo PINK (+) AT WIPER CONTROL SWITCH Wipers-Hi GREEN (+) AT WIPER CONTROL SWITCH Parking Brake YELLOW (-) AT PARKING BRAKE SWITCH MAY ALSO BE BLUE ON SOME MODELS Trnk Release BLACK (REV) AT BECU MODULE IN VEHICLE FUSEBOX Remote Start WIRE COLOR POLARITY LOCATION Battery BLACK (+) IGNITION SWITCH HARNESS Ignition 1 YELLOW (+) IGNITION SWITCH HARNESS Ignition 2 PINK (+) IGNITION SWITCH HARNESS Accessory 1 WHITE (+) IGNITION SWITCH HARNESS Starter 1 BLUE (+) IGNITION SWITCH HARNESS Starter 2 GRAY (+) IGNITION SWITCH HARNESS Anti-Theft Type UNIVERSAL IMMOBILIZER Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER Key Sense BLUE (-) IGNITION SWITCH HARNESS THIS WIRE WILL DISARM THE FACTORY SECURITY WITHOUT UNLOCKING THE DOORS Tachometer BLACK (AC) AT DATALINK CONNECTOR UNDER DRIVER DASH Speed Sense VIOLET (AC) RADIO HARNESS ALSO AT AMPLIFER UNDER PASSENGER SEAT Parking Lights BLACK (-) AT BECU MODULE IN VEHICLE FUSEBOX Brake Lights WHITE (+) AT SWITCH ABOVE BRAKE PEDAL Reverse Lights RED (+) IN HARNESS IN DRIVER KICKPANEL Horn WHITE (-) AT VEHICLE FUSE BOX Modules WIRE LOCATION Please select another category Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock GRAY (-) IN HARNESS IN DRIVERS KICKPANEL USE A DOUBLE PULSE TO UNLOCK ALL DOORS PowerLock BROWN (-) IN HARNESS IN DRIVERS KICKPANEL LF Window Up GREEN (REV) AT DRIVER WINDOW SWITCH LF Window Dn BROWN (REV) AT DRIVER WINDOW SWITCH RF Window Up WHITE (REV) IN HARNESS IN DRIVER KICKPANEL RF Window Dn RED (REV) IN HARNESS IN DRIVER KICKPANEL LR Window Up BLUE (REV) IN HARNESS IN DRIVER KICKPANEL LR Window Dn BLACK (REV) IN HARNESS IN DRIVER KICKPANEL RR Window Up YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL RR Window Dn LIGHT GREEN (REV) IN HARNESS IN DRIVER KICKPANEL Sunroof Open BROWN (-) AT SUNROOF CONTROL SWITCH Sunroof Close BLUE (-) AT SUNROOF CONTROL SWITCH |
