RCA length '08 Camry
I'm about to run 2 amps in my trunk. Does anyone know how long my rca cables should be. I was thinking about 25 ft. It's an '08 Camry.
Thanks[/align] |
RE: RCA length '08 Camry
Where are you putting the amps?
I haven't decided if I'm putting them on the back seat or vertically on the driver's side rear corner of the trunk.
Thanks |
I would recommend to put them on the back of the back seat. If you do that you should only need 17 ft Rca's.
Well if your not sure just with string and measure it out....always buy longer than needed because it sure does suck when it wont reach...i think 17 feet is a good length for that location
Thanks for the responses. I got the RCAs and will hopefully have everything up and running by this weekend.
