Camry color does not shine
Your best bet is doing an internet search on faded Toyota paint. There are lots of hits including some from Toyota dealers plus Youtube video's. Keep in mind there may be a clear coat over the color code. You want to use the most MILD method first. Most likely the clear coat has oxidized from the sun and needs to have the oxidized material GENTLY removed.
Look into using something called a "clay bar."
Before you do any do anything read up as even a clay bar if not used correctly can cause scratches.
Wash the car first to remove dirt, etc before starting.
A good website to check out is Toyotanation.com as all they deal with is Toyota issues faded paint included.
To restore the faded and rough areas on your 2017 Camry's hood and roof, consider using a high-quality car polish or compound designed for clear coat restoration. Apply it with a soft cloth using circular motions. Follow up with a wax to protect the paint and enhance shine.
robert32
09-16-2022 01:20 PM
