Little access panel next to steering wheel..
Okay, so the previous owner of my 94 camry decided to install some aftermarket fog lamps. Not only did his wiring not work (no grounds attached, all one big mess) but he alsoinstalled the swith into that little panel to the right of the steering column, the access panel to one of the bolts to remove the dash. I finally completely redid the wiring and the lights now work, but that panel I guess the previous owner tried to force in the wrong way because it keeps on falling out of place. Any thoughts? I already checked on ebay and theres NOTHING there for "94 camry dash clip thingy"So my question is.... does anyone have any thoughts? What can I do?
RE: Little access panel next to steering wheel..
Yea I used to work at a junk yard, they charge $30 for a stock mirror, when I could ge a pair of carbon M3 mirrors for $27. I dont even wanna know what they'll come up with for a little plastic thing. Thanks tho, I'll check into it anyways.
Okay, I know, dead thread, but I figured I'd mention, I did get a new panel from a junk yard. And discovered the other one didnt fit due to the switch for the fog lights. The contact for the switch was in the way of the metal behind that panel, so it didnt sit.
The car in the background?? Good eye, yea it is a Cutlass Cierra. It's been sitting for a while, apparently the head gasket went and in the process of fixing it they hit a frozen bolt. Couldnt continue. Everything else is in great condition, the body looks almost flawless. I can prolly take a couple pics and PM them to you if you want.
tsidrift1
07-17-2011 01:04 PM
