02 Camry 2.4L throttle bode hose connection
1 Attachment(s)
Just did the Time Sert fix and putting everything back I ran into a dilemma. This hose is at the right side bottom of the throttle body going down towards the floor. There are 4 total 2 water bypass on that comes from the air filter box assembly and this one the is down at the bottom right as you look from the passenger side fender towards the inside of the car. Have a picture loaded. Thanks in advance.
99 views .no reply .. picture of engine bay area looks normal
the 2 hoses are heater /coolant size hoses one should be inflow and the other out flow to the internal heater box does that answer the original question the hose in centre picture from the black box looks like it needs a clamp |
