'02 Camry SE with rear blinker problem
my passenger-side rear blinker went out this week and i just tried to replace it yesterday. i bought a new 921 wedge light bulb that it asks for but no luck... any suggestions would be greatly appreciated
Use a volt/ohm meter.
Probe the socket to determine if power is getting to one bulb socket terminal when flasher or the turn signal switch is on. Power wire might be Green/Yellow.
With system off use ohm meter to probe the terminals, the non-powered terminal should be grounded to the chassis. White/Black wire.
Thanks for all the help guys. Turned out I had just bought a bad bulb from NAPA. Thought I had faulty wiring because of it. Had to pay local repair shop to figure this out for me. At least they are friends... Thanks for all the help!
keystone1979
07-09-2011 10:39 AM
tt837
10-07-2010 02:11 PM
moh.vze.com
03-06-2008 05:11 PM
