'05 Camry - Stripped bolt that is difficult to reach
Old 09-09-2012, 04:43 PM
Default '05 Camry - Stripped bolt that is difficult to reach
I am working on replacing the water pump of a 2005 Toyata Camry and I accidentally stripped one of the bolts on the pulley above the water pump and cannot get it off.
Tried using vice grips and they did not work because I couldn't get a grip on it plus the vice grip is in the way of allowing me to turn it even if I were able to get a good grip. Also, I used a damaged bolt/nut remover set but the socket is too wide to reach down to the bolt.
Any ideas other than vice grips or damaged bolt removers to get this stripped bolt off?
Old 09-09-2012, 05:02 PM
can you please post a photo of the area
Old 09-12-2012, 01:28 PM
Maybe use a dremel and dremel a slot and use a flat head screwdriver.
Old 11-26-2012, 01:02 AM
Take Your Time to Indulge on All the Awesome DVDs - Homeland Season 1 DVD in the World!
pauper
05-10-2013 08:39 PM
DIYGIRLY
02-13-2013 09:27 AM
jhonsonmike
07-05-2011 10:21 AM
bouyang
12-30-2008 01:56 PM
bouyang
12-30-2008 01:49 PM
Quick Reply: '05 Camry - Stripped bolt that is difficult to reach
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
