06 Camry 2.4 Trick to remove exhaust manifold bolt by alternator?
Old Sep 17, 2024 | 12:43 AM
g20zoom's Avatar
Default 06 Camry 2.4 Trick to remove exhaust manifold bolt by alternator?
2006 Camry 2.4L with the upper exhaust/Catalytic converter for the CA model.
So I got the dreaded P0420 that comes on shortly after reset. I do have 220k, so it's somewhat expected. There's two 12mm nuts on the top exhaust manifold and easy to remove. The lower 3 nuts, 2 are easy to get to but the one in the lower left when facing the engine, the one next to alternator was difficult to access. I've seen on youtube where a slim flex wrench does the trick.
Can anyone point out a specific affordable wrench that does the job WITHOUT removing the alternator? amazon ones maybe? I tried the HF Pittsburgh ones but didn't work since not slim enough i think.
I ended up removing the alternator top 14mm bolt and lower 12mm bolt but considering I have to pull my CAT again, I'm looking for a more efficient method. long story - I bought a CARB legal Cat however the smog place failed me!! on the visual. Apparently the CARB EO# and "Test Group" number under my hood did not match!! So basically there only 2 options out there with the Toyota one being the cheapest at ~$1100-1200. Considering I just lost $500 on CARB cat that won't pass.....I'm screwed over.
Old Sep 18, 2024 | 09:00 PM
Oh no! This is terrible! So sorry to hear.
I was going to recommend exactly what you did, remove the alternator. Seem like a lot of extra work but should overall be quicker.
Good luck.
RapidOne
Nov 26, 2020 10:34 AM
c.chan
Aug 7, 2020 01:35 AM
wdc123
Mar 14, 2016 11:32 AM
jimhey
Nov 28, 2011 07:05 PM
turborally
Jul 8, 2008 06:31 PM
