12v outlet auto shutoff bypass
How do I bypass the 12v outlet auto-off on the 2012 Camry? Is there a place for a jumper in the fuse box?
Auto off as in turning off with the ign key?
Power outlet goes to the PWR Outlet fuse which controlled by the ACC relay. This relay also power other fuses. Would need to isolate the PWR Outlet fuse then jump to the circuit that powers the ACC relay. Might be better of rewiring the outlet to a constant source of power inside the car. |
(Post 77544)
Might check at the Toyotanation website as to someone doing this.
