1989 Camry 4 cylinder spark plugs
Hi,
How often should I change spark plugs? Should I just use the regular/copper plugs, or should i use platinum or iridium? thanks!!!!! |
Suggest Denso brand platinum. Platinum can last 100K miles. The extra cost of platinum plugs is minimal verses copper and they last a lot longer.
Thanks. Do platinums need to be re-gapped?
I use about 1/2 quart every 1,000-2,000 miles. There is no change in mileage or check engine light on. I just checked the exhaust and there is no smoke. However, I just regapped my spark plugs, #1 and #3 threads have fresh oil. What does that mean? |
Depends on what the manufactured plug is gaped at. If gaping only move the ground electrode and don't apply pressure on the center electrode. Use a gaping tool.
Most owners never gap a plug. The threads of 1 and 3 have motor oil on them? Use a flash light and check for motor oil getting into the spark plug tubes. The tube is pressed or screwed into the head and can leak. Unless there is a lot of oil in the tube as in getting onto the spark plug socket, would not be concerned. |
