1990 Camry Lights failure and more!
Hi all!
Ok before shrugging this off as another ' lil yellow box failure ', in which I have searched for and it seems to be a very common problem.
Mine seems to be a bit more terminal. Indicators and hazards are inoperable, and when I apply the brake pedal the Charge light comes on on the dash and the engine will eventually stall out (due to lack of voltage) . I have monitored the voltage drop when brakes are applied before.
I note in the not so trusty Gregory's manual , that alot of the cars electrics are routed via this ' lamp failure box '. It seems to get its power form a tap that connects to the starter motor. I belive this is the point at which this relay is sucking the energy from the rest of the car.
I will look for the lil yellow box tonight and any other wiring issues.
Am I on the right track? Or does anyone have any other advise? Car is off the road till I can get this sorted out
My shopping list so far includes :
Flasher relay
Lamp failure relay box
Possibly new alternator ?? (It does not seem to be suppling much charge back to the battery) - battery was new 3 months ago.
HELP PLEASE! ( I think I have posted this in the right area, please move or let me know if it's not )
Flasher relay
you should have your alternator checked out at your local autozone. They do it for free all you have to do is take it off and bring it to them. I wouldn't suggest driving your car there and getting it tested with it on, I did this a while back on my MR2 and they said everything was fine when it was seized. Really easy to get to just pop your hood and wham its right there.
Carrie Leo
03-07-2013 07:03 PM
Lovehatetony
10-21-2011 10:05 AM
