1992 Camry wont start
I have a 1992 camry with 110k miles.
One month ago I replaced the distributor cap, rotor, and coil. Now one month later, while I was driving last week, the car stalled when I stopped at a light. I now have no spark. I have proved that the following parts are in good working condition, the igniter, spark wires, distributor, distributor rotor and the car still won't start. All of my fuses are also good. I don't have any spark.
Any help would be appreciated,
THANK YOU
THANK YOU
THANK YOU
THANK YOU
Does the engine crank? If it does and it sounds kind of wheezy, it might be a timing belt. Check and see if the rotor is turning when you crank. Had it happen to me on my 92 Camry last year. Expensive for a shop to fix, but isn't that bad if you do it yourself.
