1998 camry dash lights..fuse???
1998 2.2 Camry automatic.
The tachometer light and the ac/heater DASH lights don't work. Is this a fuse problems or a bulb problem? Thanks |
Check panel fuse.
Cig lighter and ashtray lights are on the same power junction with bulbs grounded to common junction. Radio and glove box are on same junction as dash light with a common ground If any of these lights work the fuse is OK. If lights on the same junction work then junction power is OK. |
Chances are it is a fuse that needs to be replaced.
If you can test the fuses that are under your dash. |
It seem to be a bulb problem, I think that happen to me and the mechanic told me it's has something to do about the bulb.
