1999 Camry Power door actuator Removal
I have a 1999 Camry LE 4 cylinder. Can you give me help on removing the driver door power lock actuator. I have removed the door trim and located the actuator on the inside of the inner panel but not sure how it is attached to the panel. Any help is appreciated. Joe
There are three screws on the side of the drivers door holding it on. Before removing the screws make sure to disconnect the various rods and links to the actuator.
Thank you. Joe
