2000 Toyota Camry Vaccum Leak
Check Engine light on and computer says Vaccum Leak so What do i check for? i notice my power steering fluid is everywhere under the 5 steel lines |
I'd start by removing your air box and then follow with an inspection of all hoses within the general area. Mainly be on the lookout for rubber hoses as those tend to fail after 11yrs. I've had some bust but they were vacuum hoses connected to the manifold and air box. as far as pwr steering fluid that'd be the main vicinity I'd start looking. once you remove that air box though you'll be able to better inspect though.
