2001 Camry fuse diagram?
I have an 01 V6 Camry. The air has quite working and the air light blinks. I thought it might be the relay, but I don't have an owner's manual to know which relay is for the air conditioning. Can anyone help me out?
Thanks |
can't you find one in the web? you might find in Camry official website...
There is a long narrow relay box on the drivers side of the engine compartment.
There are 5 relays, the compressor clutch relay is located on the opposite side of the fuses. The AC fuse is also located there. Check the relay, if not the problem post back. |
No, I couldn't find one on the web, but I did order the relay and luckily it was smaller than the other relays, so I automatically knew which one to replace. The new relay did the trick and it's working fine now!
Great!
