2001 reverse wire near the front of car location and color
Hello, I have a 2001 toyota camry ce. I am trying to install the reverse signal wire that comes of my pionert avh4400bh headunit. I understand I need to tap into the reverse bulb lights in the rear to give the reverse camera power. ( I haven' t started this yet so any help is appreciated. )
. There is a purple wire labeled reverse on the head unit so when the car goes into reverse this will let the receiver know to put the camera display on. Could anyone help with the location and color please. Thank you. |
The wiring harness for the trunk runs down the drivers side kick panel.
Can tap off the back up light switch (stick shift) or park/neutral switch (auto). Or wire going to the reverse indicator bulb on dash. All wires colors are Red/Black. There may be more then one wire. The wire will be +12V when the shifter is in R. |
(Post 96905)
Most likely no. The correct Red/Black wire have 12V when the trans is in R.
(Post 96916)
(Post 96916)
They did have the red/black and white wires going to those lights. I am kind of on a time crunch because I am trying to surprise my gf for her bday next month and really have no time to check with voltage meters. So any help with where the wires go from there would help me tremendously. I snuck the car today but really got lucky. I looked for those same wires but didnt see any red/black wires running down to where the rest of the bulk of wired go along the drivers side floor board. Could they turn off somewhere? Or maybe run along the top of the roof liner? |
Try this.
Look under the passengers side of dash (below glove box) for a wiring harness plug having 12 pins in 2 rows of 6. Look for a plug having two Red/Black wires next to each other on the retaining clip side of the plug. |
Wiring colors for reverse lights
(Post 96905)
Do you have wiring diagrams for the stereo and camera?
(Post 97049)
