2001 reverse wire near the front of car location and color
Old 12-23-2017, 09:33 AM
Default 2001 reverse wire near the front of car location and color
Hello, I have a 2001 toyota camry ce. I am trying to install the reverse signal wire that comes of my pionert avh4400bh headunit. I understand I need to tap into the reverse bulb lights in the rear to give the reverse camera power. ( I haven' t started this yet so any help is appreciated. )
. There is a purple wire labeled reverse on the head unit so when the car goes into reverse this will let the receiver know to put the camera display on. Could anyone help with the location and color please. Thank you.
Old 12-23-2017, 11:48 AM
The wiring harness for the trunk runs down the drivers side kick panel.
Can tap off the back up light switch (stick shift) or park/neutral switch (auto).
Or wire going to the reverse indicator bulb on dash.
All wires colors are Red/Black.
There may be more then one wire. The wire will be +12V when the shifter is in R.
Old 12-23-2017, 04:29 PM
OK so the color red/black will be the only wirea for the reverse? ( Unless of course , someone ran a wire red/black for something. I get that. ) But in general all the red with black stripe is for the reverse? This is an automatic. Sorry
Old 12-23-2017, 06:07 PM
Most likely no. The correct Red/Black wire have 12V when the trans is in R.
Old 12-23-2017, 08:12 PM
OK. I appreciate the help. It' 's enough info for me to think I can , I think I can..... I think I can.... etc.
Old 12-24-2017, 10:07 AM
OK. I think the bulbs for the reverse on this camry are the ones that are on either side of the license plate correct?
They did have the red/black and white wires going to those lights.
I am kind of on a time crunch because I am trying to surprise my gf for her bday next month and really have no time to check with voltage meters. So any help with where the wires go from there would help me tremendously. I snuck the car today but really got lucky. I looked for those same wires but didnt see any red/black wires running down to where the rest of the bulk of wired go along the drivers side floor board. Could they turn off somewhere? Or maybe run along the top of the roof liner?
Old 12-24-2017, 02:26 PM
Try this.
Look under the passengers side of dash (below glove box) for a wiring harness plug having 12 pins in 2 rows of 6. Look for a plug having two Red/Black wires next to each other on the retaining clip side of the plug.
Old 01-09-2018, 06:43 AM
Default Wiring colors for reverse lights
. So I have hooked up my head unit. No issues. I ran my cabling for the camera to the rear reverse lights to the head unit. I plugged in the video to the headunit. I ran an extra wire for the reverse portion as well. (So when in reverse the camera would turn on automtically. ) I ran the power from the camera to the reverse bulb. I believe the red/black is the 12v reverse trigger and the white is ground? So I hooked up the power from the camera to the red/black and the negative of the camera to the white. I then spliced the extra reverse trigger wire that i ran into the red black wire. Does this seem correct? Or do I need to find a different power or ground source?
Old 01-09-2018, 11:02 AM
Do you have wiring diagrams for the stereo and camera?
Old 01-09-2018, 11:23 AM
no. I can' one on the great world of Web either.
Quick Reply: 2001 reverse wire near the front of car location and color
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
