2001 reverse wire near the front of car location and color
#11
Some "experts" state to make sure the camera power and ground are at the same source. This to avoid voltage fluctuations. But others state taking the power from the backup light source is OK.
The camera would have a trigger wire typically blue or green. Plus the power wires.
The head unit may or may not have trigger wire. Its possible for monitor to sense the video signal to turn it on.
#12
#13
Wiring diagrams are illusive.
Other then the audio/video cables with assume RCA plugs. The camera has exactly what wires and what color are these?
Are you sure the cameras is not powering up or is the head unit not displaying the video.
#14
Could be either one being the problem. I ordered amother oNE to rule out the camera or wires being the fault. I am trying to rule out if my wiring is correct and it can be wired with the black red wire being positive and the white black wire being a ground. If this is OK to wire this way then I'm sure the problem lies with the components.
#16
. This is an easy as s#!t /pie wiring job like I thought it would be since its an older car. I ran a two wire to the rear just in case something happens in the future. The rear bulb is the 2 lights on either side of the license plate. To access this you need to remove the back cover. (Few Plastic clips).
I drilled a hole big enough for he wiring, placed a small grommet on it. And used silicon to cover it so no water could enter the vehicle. I placef the camera above the center of the license plate. It looks really good there. The positive wire and reverse trip wire is the black/red wire on my car. The ground is the white /black. Connect the camera this way and you shouldnt have a wiring problem. I used small zip ties to secure it. Run the av cable to the aftermarket head unit or rear view mirror. All done.
THX FOR ALL THAT HELPED.
moshlub
07-10-2009 12:59 AM
