2004 camry brakes
the left front brake caliper siezed up on me, I replaced the caliper replaced pads and turned both front rotors but the left side is "dragging" almost as though I have my foot slightly on the brakes, right side is fine, any suggestions?
Did you lube the slider pins?
if the left seized on you then the right was going to be close behind, need to replace them both.
