2005 4 cyl spewing antifreeze
Old 11-09-2013, 11:17 AM
Kmahoney's Avatar
Default 2005 4 cyl spewing antifreeze
This morning my 2005 SE 4 cyl began spewing antifreeze from small slots on the top left side of the radiator. Have and now leakage up to now. Do I have to replace the radiator or is there a common fix?
Old 11-09-2013, 11:54 PM
The top and bottom covers of the radiator are plastic. It is fairly common for the top cover to crack then spew out coolant. Determine if the small slots are really cracks in the upper cover.
Or is the fluid coming out the finned area that makes up the bulk of the radiator front and back?
Either way, most owners replace the radiator as aftermarket radiators are low cost.
If it is the plastic cover leaking, there are kits that can patch the plastic but sooner or later new cracks will form thus do not recommend this.
millerl513
07-15-2013 08:16 PM
redbaron0005
02-16-2012 08:17 PM
dune_myster1
04-02-2009 01:05 PM
nuttintoaboss
02-19-2008 11:09 AM
rollsride
10-31-2007 01:48 AM
Quick Reply: 2005 4 cyl spewing antifreeze
