Smileyfta |
04-15-2022 07:38 PM |
2007 Camry SE 3.5L V6 Recommended Ignition Coil Brand Replacement
What is the recommended replacement ignition coils for 2007 Camry 3.5L V6? It has 240,000 miles but appears to have been maintained. Not sure when or if the coil packs were ever changed. I have error code P0356 & am replacing #6 Coil along with all 6 spark Plugs with Denso Iridium's #3426 which is the recommended OEM Iridium replacement plugs, intake manifold gaskets, & the throttle body gasket. I'm just not having luck finding a recommended Brand for the coil pack.
To dum up, I'm needing to know what brand everybody recommends for the ignition coil. Also your thoughts on should I also replace all 6 coil boots &/or anything else I should replace while at it? Not sure if should go ahead and replace the other rear coil pack behind the fire wall while im in there or not? I've actually found a good price on all 6 coil packs made by ENA that I can buy 6 ENA Coils for price of 2 Denso Coils. Just not sure what all should do being on a budget but don't want to go with the wrong parts because of price & end up costing me more $$ in the long run on a Camry with 240,000 miles. Thanx I'm advance!!
