2007 Door Lock Problems
I have a 2007 Camry XLE, and currently have issues with the door locks. When I use the power lock button either in the car or on the key, the only door that locks is the front passenger door. The other three don't do anything. Also, when using the key to unlock the car, the driver door sometimes has issues actually unlocking the driver door.
Any ideas why these things might be happening? I figured it was just the power lock actuator, but would three of them go out at the same time? Does anyone else have this issue? Thanks for your help! |
bumpin' to find some advice
Do the individual door locks work?
when you physically lock the doors from inside, yes the door is actually locked.
Sounds like the same problem described in this thread:
https://www.camryforums.com/forum/ec...or-locks-3143/ Basically, it's an issue in the computer and/or fuse box and requires replacement. |
