2009 camry my driver side low bean bulb won't work.
I have changed the light bulb and it still won't work. is there a fuse for each light bulb? can someone help?
There is a fuse box inside the engine compartment, left side.
Look for fuses labeled H-LP then LL or RL for lower left or lower right |
you may have bad socket, and it can be replaced.
you may have blown fusible link in wire. good luck. you do not have per light bulb fuses. on my wife's RX300, high beam on pass side does not work. who gives. has no power to it. you can run parallel wire from working light wire. I have that on my son's Eclipse for about a year now. works. |
Thanks joey. It was a fuse that was out. thanks for your help.
Great!
that's great! you bought new fuse or you fix it?
My car came with spare fuses so i didn't have to buy one. :-)
