2009 camry power seat fuse
I opened the fuse box under the hood, but was not able to locate or pull out the power seat fuse. Any help on this matter will be greatly appreciated,
Thanks. |
The fuse may be a fusible link. A section of wire designed to burn through if when overheated.
There is typically is a fuse box behind the drivers side ash tray/coin box door on the lower left side of the dash board. Plus a fuse/relay box behind the drivers side kick panel. A plastic panel on the lower left wall of chassis under the dash board. Look in this two places for something labeled P/SEAT. It's 30 amps. |
