2010 Cigarette Lighter fuse out
Hi everyone,
New guy here. My wifes 2010 camry LE lighter no longer works. Im assuming its the fuse since nothing that plugs in works. I think there are two lighters in the cabin and none work. Where is the fuse located? Never really touched her car before. Any info will be appreciated. |
The may be a lighter fuse labeled CIG.
Location of fuse box may be behind the small coin box/ash tray/? on far left side of dash board below one of the climate system air outlets. Remove the box lid and look behind. |
I found the fuse on my 2010 Camry LE! It's down below, to the left under the steering wheel in a liitle pop-off fuse box. Just pull off the lid and look at the schematic. The fuse is on top, 4th from the right....
Thanks guys. Havent checked this out. Will look at it soon and report back.
Sup folks, so forgot to come back to this. I checked fuse and it was actually fine. I replaced it but still no dice. Can't think of any other thing that may be the issue. Both lighter locs do not work.
You sure these aren't the power outlets? If so, check the 20A PWR OUTLET fuse.
