87 Camry Passenger Door Panel
How do you remove thw passenger door panel without destroying it?:confused:
Remove the manual window handle (pushes onto a shaft and held on by a clip), if power windows remove the switch (gently pry out) and door handle (remove screw-look behind door handle to see and gently pry out).
The panel is held in by plastic push pins that are pushed into holes on the door frame. Us a putty knife or other thin wide tool to gently pry between the panel and door frame. The pins can break off, be gently and patient. |
Thanks
