87 Camry Passenger Door Panel
Old 06-05-2011, 04:15 PM
Question 87 Camry Passenger Door Panel
How do you remove thw passenger door panel without destroying it?
Old 06-05-2011, 08:57 PM
Remove the manual window handle (pushes onto a shaft and held on by a clip), if power windows remove the switch (gently pry out) and door handle (remove screw-look behind door handle to see and gently pry out).
The panel is held in by plastic push pins that are pushed into holes on the door frame. Us a putty knife or other thin wide tool to gently pry between the panel and door frame. The pins can break off, be gently and patient.
Old 06-06-2011, 06:24 AM
Thanks
Viktor
05-17-2012 09:11 PM
GTScott
02-25-2008 11:29 AM
Graybeard
11-05-2007 09:10 PM
cmrylovr
07-30-2006 05:10 PM
mhamlin
01-13-2006 09:41 PM
Quick Reply: 87 Camry Passenger Door Panel
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
