87 Toyota Camry 4 Cylinder manual Power steering pump ?
Hello Only when the car is cold and you turn the steering wheel you hear a loud squeaking noise. I checked the belt and it seems to be somewhat new and tight. I checked the power steering fluid level that is good. So my questions to you are..... Are the power steering pumps notorious for leaks or going bad in 87? What are the signs/symptoms of a power steering pump going bad? How can I find out if I can fix the noise or if I need to replace power steering pump? Have you heard of this problem or similar in a 87-91 Toyota Camry? Thanks for your help in these matters.
Dave
Dave
hardyrxp
02-01-2010 10:16 AM
hardyrxp
01-30-2010 11:11 PM
