88 camry no power to distributer
I have a 1988 Camry that isn't getting any spark I have replaced the coil distributor cap plugs and plug wires. I have also tested the incoming wires to the distributor and there is no power there. I have checked all the fuses and they are all good. I have also cleaned all of the ground connections that I could find. Any help would be great.
Brown/orange wires on engine are 12V from ign switch (ign switch on).
Check for 12V power at brown/orange wires such as fuel injectors (ign switch on). If no power check ign switch and 30A (or could be 35A) fusible link in small plastic box inside engine compartment. Fusible link is a larger fuse looks like photo below: http://ts3.mm.bing.net/th?id=H.50439...h=181&c=7&rs=1 |
