92 Camery LE 2.2 Auto Transmission problem
Old 11-08-2016, 10:35 PM
Default 92 Camery LE 2.2 Auto Transmission problem
A while back, I bought a 92 Camry 2.2L A/T with 94K miles. It ran great and was in very good shape. We've put about 6k on it since. Recently, I noticed an oil leak; valve cover gasket had oil running down the back of the engine. Then the transmission started acting up.
Engine runs normally, but when put in drive, it accelerates very sluggishly, eventually reaching cruising speed, but no power. Reverse works fine, hit the gas and she flies backward. First gear appears to work fine as well. If you put it in second going down the road, it will surge ahead, then slow way down, then surge again.
Could the leaking oil have gotten into the solenoid connections and be causing the problem? Wondering, because both occurred about the same time. I replaced the valve cover gasket and stopped the leak.
The tranny fluid is full, red and no burned smell. No transmission fluid leaking.
Any ideas?
Old 11-08-2016, 10:42 PM
if the motor performs well
my thoughts
faulty TPS ..(throttle position sensor) can cause this issue
has an adjustment or replace
your description of tranny oil and color
says transmission is in good shape internally
automatic gearbox solenoids are internal
engine oil leaks are not normally the cause of automatic fault
Old 11-08-2016, 11:08 PM
Thanks for the quick reply. I just went out and did a stall test. Drive was 2400 rpm, reverse was about 2350.
I'll pick up a TPS tomorrow and give it a shot.
Buddy from Lubbock
07-17-2015 10:09 PM
strausbo
06-18-2014 08:43 PM
stubirdnb
11-21-2008 01:17 PM
Quick Reply: 92 Camery LE 2.2 Auto Transmission problem
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
