'94 V6 LE Downstream O2 sensor replacement...
Have all parts and tools ready. I can pop the console coin holder, the one to access the parking brake adjustment, and see the O2 sensor wire harness, but can barely get one hand in there to get near it. I see the wire and grommet feed through side of console/exhaust tunnel and it probably won't easily feed back up with the new O2 sensor since it's tight against the carpet/seat/console.
Not really looking to remove passenger seat and entire console. If anyone has done this before, how did you do it? |
Would it be easier to do from underneath the car? Do you have a repair manual like Haynes? I wish I could give you some solid advice on this but I'm not up to speed on the V6's. This is the rear O2 sensor, right? Hit that thing with some PB Blaster and also run the car a bit to get the pipe warm. If that sensor has been in there since '94 it is probably pretty well rusted in, every little bit is going to help.
Job Completed : My Step-By-Step (elapsed time <1hr)
Awesome job! Thanks for posting this DIY! Someone should sticky this! Pretty involved job you had to do and I never would have thought that you would need to pull the seat out to do an O2 sensor!
Congrats and thanks for sharing. |
Thanks! The seat removal turned out to be a non-issue. I was more concerned with the possibility of removing part or all of the console. Which, as it turns out, can only be done after removing both seats because of the two screws on each side of the console behind the side of the seats.
Ugh! They must have built that car around that sensor! Again, good job sir!
