97 camry waterpump
I have a 1997 Toyota Camry. It is leaking anti-frezze. I need to replace the water pump. Do I have to remove and replace timing belts too?
The pump is powered by the timing belt (only 1), thus it needs to be removed.
As to replacing the belt, when was the last time it was replaced? Recommended change period is 90K miles or 6 years. |
^+1
Worth replacing the timing belt tensioner too why you are at it. |
