98 camry sputtering
hello i have a problem with my 98 camry 2.2 lit automatic,, when you take off it sputters and acts like it wants to quit,,,but when you give it more gas it goes ok..also the check engine light is flashing.......i have replaced the coils.. put a new tps sensor on it...and the front oxygen sensor.. checked all plugs and put new sparkplugs in it. and cleaned the fuel injectors. and i cleaned the egr valve. and checked all vacum lines....after all this it seemed to help it but it still is doing it...im thinking maybe map sensor or clogged cat converter....anyone know...thanks
A flashing check light typically indicates a problem that needs immediate attention as it may result in damage to components such as the converter.
Suggest you read out the trouble codes. |
