99 Camry 2.0 exhaust cam service bolt (help!)
So i pulled a dummy on my first rebuild and removed cams without installing the service bolt on the exhaust cam, how do i re-align the cam?
humm 15 days ago ... might be sorted
no replys yet ..after 55 views .. thats unusual a 2 lt engine used in the 99 model ... I assume it is a 4 cyl ... and you needed to align the exhaust cam to help anyone else in the future ... someone may need to add a picture and maybe if its there some information from that engines repair manual |
Thanks!
Hold the long end the of cam (from gears) from rotating. Then rotate the pulley half on the short end of cam clockwise and align service bolt holes. Install bolt.
