ATF dipstck reading problems
Old 04-23-2017, 11:56 PM
indiglofish61's Avatar
Default ATF dipstck reading problems
Everytime I take the ATF dipstick out it is wet way over the top of the hot mark, i drained the atf to refill and stopped filling after 3 qts, to check and it was so hard to get a reading cause of the wet stick, and I know it is not over filled cause I took out more then 3 qts. Is there a better way to check the level on the stick, I even wait till the fluid is drained down before checking but still hard to read. Thank you.
Old 04-24-2017, 02:20 AM
dirty hands's Avatar
which model camry is this ?
you have to give the new oil added time to drip through the dip stick tube
and settle .............before rushing the reading
how to check the level
keep motor running all the time and auto oil warm
car on level ground
cycle all gears return to park
take out and wipe dip stick
dip stick in and out again
take reading
should be between cold and hot
start at 15 seconds end 1:55
Old 04-24-2017, 08:05 AM
mothorton's Avatar
I got small holes ( 1/32" diameter or thereabouts) drilled in my dipstick (oil dipstick too!) at each check line at a machine shop ... cost me $5.... if oil doesn't reach hole it will be empty, if that makes sense..... works fine for me!
yk17
10-14-2012 11:02 AM
MoonRiver
09-15-2012 01:06 AM
sjrugged
03-25-2009 04:25 PM
Axxis8203
02-05-2009 06:42 PM
zcpro
01-12-2009 01:59 PM
Quick Reply: ATF dipstck reading problems
