ATF dipstck reading problems
Everytime I take the ATF dipstick out it is wet way over the top of the hot mark, i drained the atf to refill and stopped filling after 3 qts, to check and it was so hard to get a reading cause of the wet stick, and I know it is not over filled cause I took out more then 3 qts. Is there a better way to check the level on the stick, I even wait till the fluid is drained down before checking but still hard to read. Thank you.:confused:
which model camry is this ?
you have to give the new oil added time to drip through the dip stick tube and settle .............before rushing the reading how to check the level keep motor running all the time and auto oil warm car on level ground cycle all gears return to park take out and wipe dip stick dip stick in and out again take reading should be between cold and hot start at 15 seconds end 1:55 |
Originally Posted by indiglofish61
(Post 95351)
