Auto lock does not work after ignition
Hi
My 2001 Camry LE used to lock all doors immediately after starting the car (ignition). It does not do it anymore. I am able to lock the doors manually, however from inside the car. The car also locks and unlocks using the remote keyless entry FOB. Is there any way to troubleshoot this? Thanks in advance for your time, V |
To my knowledge this is a programable method the dealer uses. if you switched a dead battery in your car or it died on you everything will be reset and need programmed agian.
hi there
your problem should be easy to be resolved you need to get the user guid for your camry and open to the doors section and you will find how to program your doors to lock there is 4 modes if you don't have the guide tell me and i'll tell you how to program |
Originally Posted by abode91
(Post 23244)
hi there
