Belts 2011 Camry 4cyl
I have a 2011 camry SE 4cyl with 90K miles. thinking I should replace the serpentine belt. two issues and frankly I'm confused.
a. I can't locate the 19MM nut for belt tensioner. Viewed camry forum you tube video - but I can't locate same tensioner on my car. My tenisoner looks more line a 2012 model. Can't locate engine code. Mfg date was 12/10. If I follow instructions for the 2012 model year I would have to take off the other belt. b. Should I replace the other belt as well? And if someone could provide a link to belt diagram it would be appreciated. Thanks for the help. |
Is the PS belt inside or outside of the other belt?
Both years have the built-in nut to allow using a tool. If possible post photo of your tensioner. |
pic of serp belt attached.
https://cimg1.ibsrv.net/gimg/www.cam...83412b2f08.jpg
camry 2011 serp belt Serp belt appears to be behind PS belt. But when I view instructions and videos of replacing the serp belt none mention removing the PS belt. What am I missing? Thanks very much for the help. |
To remove the serp belt requires removing any belt in front of it, in this case the PS belt.
The 2011 and 2012 tensioners are slightly different but both have a "nut." The nut on the serp belt tensioner is in view in the photo. The PS tensioner will also have a nut. Since both belts will be off its a easy enough to replace the PS belt at this time. Take photos of the area prior to disassemble to allow reference upon reassemble. |
