Bi Annual smog check
Old Today | 04:18 PM
mjgord51's Avatar
Default Bi Annual smog check Help
It's time for the Bi Annual smog check (California) for our 2014, I4 Camry now with 142,172 miles on it, not a hole lot of milage but getting upthere. So far no Trouble Codes popping up so not real worried about it not passing the smog test, just want to make sure all Emission stuff is cleaned before the test ensuring the test goes with no problems.
What I've started and cleaned so far with the Proper spray cleaners:
1, The Up Stream O2 sensor and will get to the rear downstream sensor tomorrow.
2, The MAF Sensor.
What I haven't found is these other sensors, or just can't see/find them.
1, The TPS, pretty tight with little to no space for a Visual.
2, The MAP, Intake manifold also in pretty tight space.
3, The CKP, not sure if it is necessary- but could be.
4, If at all these are there.
* Im just going on what our 03 Accord has, This 14 Camry might not have whats listed above.*
These last three is what I'm having trouble finding on the motor, any help or links is greatly appreciated.
Seams as the newer the cars get the tighter space gets, Not Laughing on that at all.
Last edited by mjgord51; Today at 06:48 PM. Reason: Extra info was added, 4:47 PM today
Matthew Christiani
Dec 11, 2012 01:27 PM
ToddS
Feb 29, 2012 12:59 PM
newbie888
Aug 24, 2011 08:54 AM
ImpalerCore
Mar 10, 2010 11:55 AM
yuiqwe
Mar 1, 2010 07:08 PM
